Wheel spacer assembly order?
Old Jan 1, 2013 | 06:52 PM
Ls1Mx5's Avatar
Default Wheel spacer assembly order?
I've looked a the pdf file part diagrams and have done extensive searching but I can't find any illustrations of correct wheel spacer order for the front and back. The previous owner of my bike did some questionable work to it so I want to make sure the correct wheel spacers are in place. Anyone have any pictures of the spacer order or info on which spacers go where? Thanks
Old Jan 2, 2013 | 01:39 AM
adrenalnjunky's Avatar
Well, there's no spacer on the front on the left hand side. That function is handled by the speedo hub drive. There is a spacer on the other side though. It is part# 44312-MZ1-610
The spacers on the rear axle are the same - both sides are part #: 42311-MG5-670
I looked all of this up on servicehonda.com's website: Hammond Indiana, Honda, Yamaha, Kawasaki, Suzuki, Sea-Doo, Can-Am, Polaris, Ski, Tucker Rocky, Parts, ATV, Motorcycle, UTV, Accessories, Apparel,
You can google either of those parts numbers and find several places selling them as well.
Old Jan 2, 2013 | 11:19 PM
Ls1Mx5's Avatar
Very helpful thank you
Old Jan 22, 2013 | 11:06 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
What Junky said... unless the previous owner installed an F3 rim on the rear, which is a tiny bit different. It's a common mod, to put an F3 rim on the rear, which is 1/2 wider, and the spacer on the brake-side will then be a little different - it will have a thin "collar" that faces outward.
It looks somewhat like this:
As opposed to this (F2):
ncsponger
Nov 13, 2009 10:07 AM
Bean600
May 19, 2009 12:02 PM
kpnupe
Dec 13, 2008 02:56 AM
beauschendel
Aug 9, 2008 08:54 AM
