Vibration prob @ 5500 RPM and up. Throttle hand is numb and the clutch hand is fine.
Old Aug 13, 2010 | 11:32 PM
patmetz's Avatar
Default Vibration prob @ 5500 RPM and up. Throttle hand is numb and the clutch hand is fine.
1994 CBR 600 F2
I don't know if this is normal for these bikes but when driving for any lenght of time on this bike>15 min at highway speed, the vibration of the bike makes my right hand go numb. My left hand seems normal.
Should this bike be doing that? Bike has a D&D slip on pipe could that be causing it? It is really loud and I don't like it so much, it sounds cool wshen you get on it, but it does get old. Was thinking of going back to a used stock pipe.
Any ideas on what to look at?
Thanks
Patrick
Old Aug 15, 2010 | 03:30 PM
JesseAwesome's Avatar
Kinda sorta happens on my F2, happens on my right foot peg more than anything.
Old Aug 16, 2010 | 01:28 PM
gpfan1's Avatar
My throttle hand gets numb too. Make sure that your bar end counter weight is tight. After market ones are lighter and don't damp out vibes very well. I went to some thicker hand grips to help with the problem. If your bike has not been rejetted for the aftermarket pipe, it could be running lean at the 5000+ rpm point. Make sure motor mounts are all tight too.
highwaypatrol
Jun 30, 2013 07:36 AM
Hudson91
Jul 26, 2010 07:09 PM
FLYOU
Oct 29, 2007 01:26 PM
Triangle
Aug 14, 2006 10:14 AM
