spark plug gap and jet settings
so redoing the jets in my 93 cbr 600,and bought new NKG spark plugs and was wondering if any plug gapping is req..?
and does any one know what *amount of turns are for each jet set..?
and what are the stock jet sizes..
Plugs .035, jets 135. Pilot jets for 49 state version 2 1/8 turns out, Calif version 2 3/4 turns out. 1/2 turn in for high altitude. These are starting points and you may have to fine tune with a carb sync gauge.
not right off hand, but if you can give me til tomorrow evening I can check for ya. Also, these are the front bolts correct? for the rear, the ones that hold the brake lines, I had to use lock nuts on the back side cause I was missing the pieces they actually bolt into. Have to work today, but I am installing a lowering link and such tomorrow and will get the size for you. I do know I bought them at lowes in a pack of four for like 2 dollars.
