Is this right/enough?
Old Jul 26, 2012 | 08:15 PM
Wranghondo's Avatar
Default Is this right/enough?
Is this what I need for a valve adjustment? Is there a better kit? One with something else that I might need. This will be my maiden valve adjustment so at the very least I want to make sure I've got all that I need. I'll buy a manual or find the info on line.
Amazon.com: Hot Cams Valve Shim Kit - 7.48mm OD HCSHIM01: Automotive Amazon.com: Hot Cams Valve Shim Kit - 7.48mm OD HCSHIM01: Automotive
Looks right. Anyone?
Old Jul 29, 2012 | 11:46 PM
swaskowiak's Avatar
I bought the same kit. It worked out great. Make sure you have a feeler gauge and a way to do the mesurments. I recommend a digital slide caliper.
Old Jul 30, 2012 | 07:41 AM
JankCibberf2's Avatar
thats exactly what i used, which is why im selling my old one that has been in my garage for a couple weeks now. You use a total of like 8 valves max and have like 150 or so in the set
