replacing fork seals need some info.
Old Feb 21, 2011 | 03:33 PM
tyfishfinder's Avatar
Exclamation replacing fork seals need some info.
hey guys i just noticed my forks leaking a good amount so i went ahead and ordered new seals and im going to do the repair myself i cant see paying $250 at the local shops for a job that seems pretty strait foward from what i have seen online i just need to know how much oil to fill the forks with and what weight is recommended for a 91 cbr 600f2 i dont have a manual any info would be great and i would welcome any tips you guys may have for me doing this job...
thanks in advance
Old Feb 21, 2011 | 03:41 PM
Project96's Avatar
Before 91-93 508cc of 10w oil with a level of 118mm from the top of the fork tube with the fork fully bleed, fully compressed & spring out.
After 93 460cc of 10w oil with a level of 135mm from the top of the fork tube with the fork fully bleed, fully compressed & spring out.
Old Jun 21, 2011 | 06:12 PM
higgy2011's Avatar
Just bumping this thread as I have a relevant question.
What fluid levels should I run with a set of F3 forks slotted into F2 lowers?
Cheers
Old Jun 22, 2011 | 10:04 AM
jtkardel's Avatar
I'd use the F3 fluid level. If you don't like the way it feels, you can do some minor adjustments to the level to adjust how it rides. More fluid gives stiffer damping, and vice versa.
match417
Feb 28, 2011 05:46 PM
WhiteHawk
Apr 27, 2007 05:32 PM
transamlt1man
Sep 14, 2005 10:27 PM
ugd420
May 29, 2005 01:44 AM
