Rebuilt engine, pressed starter, only clicks once
Old Oct 6, 2010 | 02:44 PM
Mike_Tuinstra's Avatar
Default Rebuilt engine, pressed starter, only clicks once
I recently tore apart my engine because i thought I broke a piston rod. No dice. So I figure its a fuel/carbarator issue.
Put the bike all back together, except for the fuel line/tank, and wanted to see if it would crank ( when I took the engine apart it would crank but made an awful noise and wouldn't start). So after I just finished putting the engine back together I pressed the starter and all it does it click once.
I thought it might be that the battery is low because it has been sitting for a while but my bike is deep in a garage and hooking it up to some jumpers would be a very difficult task so I thought I might ask you guys your input first before I move half the garage around.
Old Oct 6, 2010 | 05:30 PM
squale147's Avatar
July 2013 ROTM
yea..i would make sure your battery is at full charge
Old Oct 6, 2010 | 06:33 PM
cbr900racer77's Avatar
Just to be on the safe side, did you rotate engine with wrench first?
Old Oct 6, 2010 | 06:41 PM
JesseAwesome's Avatar
+1
Pull the plugs, and turn the engine by hand. Make sure everything moves freely.
Old Oct 6, 2010 | 07:51 PM
got it, I just forgot to conect one of the wires ........ however when i hooked it all up and went to fire it as soon as i turned the fuel on it started pouring out all over! got some more work to do and possibly a new thread coming if i cant figure it out. Just another adventure brought to you by the cbr from hell!
Old Oct 6, 2010 | 09:27 PM
Nah, she's just trying to get your attention, that's all. Sounds like simple float sticking. Nothing a good cleaning or whack across the bowl with screwdriver handle won't cure.
Optimus_Prime
Mar 15, 2011 11:34 PM
VALKYIE
Jul 27, 2010 07:27 PM
mariof
F2 Tech
Apr 16, 2010 11:37 PM
vaderf4i
Apr 17, 2007 12:27 AM
yp_urslf
Mar 15, 2006 06:17 PM
