Rear turn signals not working. Any suggestions?
I recently bought a '94 CBR 600 F2. I have had a few issues with it, but I am going down the list and taking care of them. None of the issues are major. I had to replace the front tire, the fairings were broken, the tach still doesn't work, I'm replacing the R/R and the problem I'm asking for help on now is that my rear turn signals do not work.
The previous owner has followed a write-up in this forum and made the rear turn signals flush-mounted into the fairing. It looks cool and I want to keep it the same, but they are not working. The front are working, no-problem. All of the wires coming from the bike have continuity. I've checked. I figured it was the lights, but took them off and they actually light up with power! I figured I would turn to the forum for help. Any suggestions would be great.
Thanks Guys.
Thanks Guys.
Get a voltage tester from harbor freight for like $3....remove blinker housing, Clamp your tester to ground then touch each wire coming to blinker with needle point. Press your turn signal, touch each wire and the one that flashes is the signal trigger. Connect that wire to your blinker. Green coming from bike is ground to blinker's black wire.
90% connection problem, must of been a Micky mouse job and wire came loose...somewhere.
You can't
You can't
