Rear Axle nut assembly
Old Aug 17, 2010 | 04:34 PM
The Tinkler's Avatar
Default Rear Axle nut assembly
This seems like it should be a simple question but i cant seem to find the answer anywhere on the internets.
I was pulling away from a stop sign when my rear axle nut fell off and the shaft slide out of that side of the frame. The nut appears to be gone forever.
I cant see any other damage to the bike. I got the shaft back into place and it would seem from the wheel removal schematic that i have all of the other pieces except the nut.
Now i just cant find anything that describes the size of the Rear Axle Nut. If you could let me know about the size of that nut and if i should have a lock washer of some sort in addition to the nut on there that i might be missing it would be appreciated greatly.
Thank you,
Old Aug 18, 2010 | 09:03 AM
eweppley's Avatar
Wow, your axle nut just fell off! You are very lucky it didn't do that at highway speeds.
As you can see from the above pic, there is a special washer (#5) between the swing arm and the axle nut (#4). The axle nut fits a 27mm socket, but I don't know about the other particulars like thread pitch, etc. Just take the axle shaft down to your local hardware store and match it up with a nut.
Old Aug 18, 2010 | 11:44 AM
super lucky on that one.
Thanks,
Old Aug 18, 2010 | 01:18 PM
adrenalnjunky's Avatar
that Nut is listed as a 18mm thread - sells for $4.37 On www.servicehonda.com
NUT, AXLE (18MM) for 1993 HONDA CBR600F2
90305-KA4-003 $4.37
The special flanged washer is $7.13
WASHER, RR. AXLE for 1993 HONDA CBR600F2
90559-MV9-000 $7.13
Deathrace2010
Jan 31, 2012 01:26 PM
ThaBrock
Jul 31, 2011 01:40 PM
f44life
Apr 14, 2010 03:29 AM
jnicola
Nov 2, 2009 12:14 PM
astro929
Mar 27, 2005 10:20 PM
