Problem with clutch lever bushing
Old Oct 22, 2013 | 09:20 PM
gpfan1's Avatar
soak it for a few days with penetrating oils. You can also heat it with a propane torch, but you should remove the clutch perch from the bike first. The bolt may have rusted and filled the gap to the bushing walls.
Old Oct 22, 2013 | 09:45 PM
Johnny34's Avatar
I'd soak it with PE and tap it from the bottom with a mallet. Rinse and repeat. There are no threads there to damage (except the bolt itself) because its a pivot point.
Old Oct 23, 2013 | 04:55 AM
RedBaron's Avatar
It does have a thread on the bracket so you won't be able to hammer it out, you'll need to unscrew it. Soaking it will help but it might just be that the bushing has jammed the bolt, try tapping the actual bushing to see if you can get some movement.
Old Oct 23, 2013 | 07:59 AM
f1fighter's Avatar
u can burn off the bushing as well worked when i did it just got to be careful
Old Oct 29, 2013 | 08:36 PM
JayCBR's Avatar
Did you get this resolved. I have same problem on my F2 I discovered tonight. If you got it out let me know you did it please.
Kraztsun
Apr 11, 2013 05:54 PM
F4i Phantom
Aug 28, 2009 04:30 PM
