please help me with my headlights
Have a bit of a problem with the headlights as well, at the front i have 4wires instead of 3, the previous owner must have spliced the wires in and went too far back, but its not too bad since theres 2 blue, a white and green, im sure the 2 blue make one wire, so thats not the problem. Problem is im getting very low power to the headlight when turned on, only about half a volt. Question is, are there any other switches between the left handlebar switch and the battery? (I'm not getting any voltage at left handlebar switch, and the fuse is fine but im not getting any power across the fuse port either, not sure if its supposed to or not, im more on the mechanical side, not electrical)
