Petcock issue i assume?
Okay so went on the longest ride yet this season today and all was well until the trip home. Started bogging as if i was running low on fuel but i know i had plenty of gas because we had just fueled up. Pulled over and the bike would start on choke but die when i took it off. Sat there for a bit and it cranked up and rode just fine.....for about 1/4 mile and it does the same thing again!!! well after this same routine about 6 times i made it home and now my assumption is that its the infamous f2 petcock and before i rebuild/get a new one was wanting some more input into my problem. Thanks guys!
i would take your tank off and suck on the petcock vacuum while it is attatched to the petcock and while its in the on position. if fuel comes out only when you suck on the vacuum line and no fuel comes out when its in the off position then its good and your problem is else where
sorry in a noob to this, could you explain the vaccum **** as it pertains to the petcock? i may be missing something on my bike as the previous owner kinda threw it together and im having to fix all the ****ups.
on the number 1 cyclinder intake runner right below your carbs on the far left hand side there should be a nipple this is also where you sync the carbs. the line runs up from there to your petcock. the diaphram in the petcock acts as a valve when there is vacuum its open and when there isnt its closed pretty simple stuff just hard to understand if you never seen it or your bike doesnt have it and your supposed to have it
