overheating
Old Mar 27, 2010 | 03:27 PM
98dakota's Avatar
Default overheating
i have a 91 cbr f2 i recently puchesed it overheating on me it full of coolant. i pulled the waterpump cover off and i can spin it by hand?? the oil pump light comes on sometimes too any ideas??
Old Mar 28, 2010 | 12:21 PM
kjohnson's Avatar
Radiator cap.
Start with the simple stuff first.
Old Mar 29, 2010 | 09:11 AM
98dakota's Avatar
sorry i didnt mention it before i did try a different cap
Old Mar 29, 2010 | 09:47 AM
Sand.Man's Avatar
Thermostat?
Old Mar 29, 2010 | 10:10 AM
JimmyHoffa's Avatar
something in your oil pump/water pump has busted. As crazy as it sounds the water pump actually runs off of the oil pump. A chain (inside your motor) runs down from the clutch basket, which is continuously driven by the crankshaft. The chain loops around a sprocket on your oil pump, and the shaft coming out the back of your oil pump drives the water pump shaft and spins that impeller you saw when you took that cover off.
aan310
Oct 7, 2013 06:34 AM
StriperAngler
Jun 27, 2010 10:15 PM
tommyo4
Jun 9, 2010 05:12 PM
tommyo4
Jun 1, 2010 11:25 AM
Baraider51
Mar 9, 2010 12:37 PM
