Okay, being a newbie to the site I'll post it here,
Old Mar 17, 2012 | 04:10 PM
Tort93f2's Avatar
Thanks for the link, where on earth would that be........I have the tank off, seat off, everthing exposed and nothing like that anywhere.
Old Mar 17, 2012 | 04:37 PM
estate4life's Avatar
February 2012 ROTM
here is a diagram to F3 - tank: #4 is the fuel filter
OEM Parts Honda CBR600F3 1996 FUEL TANK - Cheap Cycle Parts
Old Mar 18, 2012 | 03:21 PM
Tort93f2's Avatar
Thanks, is the f3 set up the same as the f2? I still can't see a filter.
Old Mar 18, 2012 | 03:35 PM
February 2012 ROTM
What year is your F2? Set up should be similar....but if you search everywhere and cannot fund? Then likely PO bypass the fuel filter?? Try to find your year F2 diagram, it should be located after the petcock.
Did you pull the plug? It may be bad....no fuel filter?
Old Mar 18, 2012 | 07:22 PM
Tort93f2's Avatar
Mine's a 93......I did a search, looks like Honda didn't put an inline fuel filter on the CBR's until the f3's in 95. Maybe someone can confirm that. As mentioned when I drained the tank the gas was on the brown side.
Yes, I pulled the plugs this afternoon, soaked with gas and black.
Old Mar 18, 2012 | 08:14 PM
February 2012 ROTM
Here's the 93 cbr600 f2
OEM Parts Honda SUPER SPORT (CBR600F2) 1993 FUEL TANK - Cheap Cycle Parts
Old Mar 19, 2012 | 07:52 AM
Tort93f2's Avatar
Thanks again Estate, you've really been helpful. On my 93 the tank has the petcock, one larger hose goes to the carbs, one small hose that goes to the engine (suction line?) and two that are vent hoses (?) that just hang down. If there's a fuel pump and filter on this bike am not seeing it. I'm going to the dealer today for plugs and an oil filter so I'll ask them if there's a fuel filter. Thanks again for all your help.
Old Mar 19, 2012 | 11:21 AM
February 2012 ROTM
OMG....PO may have this bike set up as gravity feed....meaning the fuel pump may have gone bad and then he bypass both the pump & fuel filter....it does work for the time being....but the thing about gravity feed is once you park bike, you gotta shut off petcock...or esle gas will flood into carb....that explains why you have gas on the plugs...plugs goes bad....maybe get a sparks here and there + too much gas...back fire....
Old Mar 19, 2012 | 11:54 AM
BannWorthRulz's Avatar
Default Spark plugs
Will spark plug cause back firing? And if so I think I need some. What would you recommend?
Old Mar 19, 2012 | 01:13 PM
February 2012 ROTM
There are many possible causes when bike back fires....among one is a foul plug...a bad spark plug. Sometimes cleaning and re-gapping can help but if you were to replace new ones, I've used the iridium ones...best is no gapping...just install & go...in Tort93F2 case, looks like the previous owner bypass the fuel pump + fuel filter. Then maybe park the bike & did not shut off petcock, gas flooded carb repeatedly...in time, mess up the spark plug...so if sparks don't ignite consistently, it will not idle properly...then too much gas...and spark will combust!!! Causing backfiring. I'm just guessing but it does sound like that's the case.
So he must reinstall a fuel pump and filter, then new spark plugs, check the coil wire for corrosion... then clean the carburetor....basically a major tune...& fuel pump
