oil leaking in carbs
Old Oct 12, 2013 | 02:44 PM
f1fighter's Avatar
Default oil leaking in carbs
i was driving normal yesterday and noticed massive smoke coming from muffler and i pulled over asap. i was doing no more than 50. when i got off the bike i noticed oil all over the wires under the carbs ect. i took bike apart and the air box was full with oil and carborator . when i took off the carbs i looked into the intake holes and 2 were fulled to the top and the other 2 were wet with oil please help me
Old Oct 12, 2013 | 08:26 PM
coalminer frank's Avatar
You didnt put too much oil in it did you?
Old Oct 12, 2013 | 11:57 PM
squale147's Avatar
July 2013 ROTM
check your engine vents and make sure that there not blocked or clogged..
Old Oct 14, 2013 | 11:57 AM
f1fighter's Avatar
well bike is fixed the wife ran the bike over so its totaled
Old Oct 14, 2013 | 12:02 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Hmm...sounds contradictory. Is it fixed or is it totaled?
Old Oct 14, 2013 | 02:00 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Are you kidding?!?!? Seriously, she ran over it???
Was it an accident, or her way of ending your headaches over it??
Old Oct 17, 2013 | 06:47 PM
f1fighter's Avatar
no we didnt brake up the bike was totaled. motor was crack all the way thru and transmission was hanging gas tank bent rim bent fork bent. found a doner bike and swapped parts and she is up and running but where is the vents you were talking about
Old Nov 12, 2013 | 04:36 AM
Scorch's Avatar
There is a oil breather pipe coming from the top of the valve cover to the bottom of the air box
craywm
Jun 25, 2011 08:47 PM
FR!TZ
Jun 3, 2011 08:32 PM
smelly_smith
Jan 2, 2011 12:26 PM
Bazman
Oct 9, 2008 04:24 AM
GreaseMonkey83
Apr 29, 2007 12:52 AM
