No power! I need help PLEASE!!!
Old Apr 25, 2012 | 10:27 AM
titus sublett's Avatar
Default No power! I need help PLEASE!!!
I ordered a wiring harness for the rectifier. I didn't get to put the on correctly because I didn't have the right equipment.
The bike ran fine. I was trying to put them on there right. During that the red and green wires touched. It was a little spark. Now there is no power. I changed the fuse and it started fine. Then when I turned it off, and tried to turn it back on no power. I tried push starting it. It doesn't work. But I can jump it straight to the starter and it turn right on. I need help. Please!!!
Old Apr 25, 2012 | 10:41 AM
74demon's Avatar
check the fuses . if it blew again, you have a short somewhere.
Old Apr 25, 2012 | 03:24 PM
underground-mpyre's Avatar
Is your rectifier bad or the plug for it and is all the plugs firmly attached to each other. Sounding like a ground is bad somewhere.
Things to look for;
-Bad rectifier or plug
-Bad starter relay or connection
-Neutral switch solenoid
-Wiring short
-Fuses blown
-Bad Stator
-Bad grounding wire
Wiring Gremlins can cause the most nerve-racking headaches on bikes.
Old Apr 25, 2012 | 06:40 PM
JankCibberf2's Avatar
i think le fuse blew again, 30 amp starter fuse
Old Apr 25, 2012 | 11:17 PM
The fuse for the relay is fine. I pushed started it today and it ran fine.
Old Apr 25, 2012 | 11:20 PM
But still no power!!!
Old Apr 25, 2012 | 11:23 PM
74demon's Avatar
Trace the power from the battery to the starter.
Old Apr 26, 2012 | 07:31 AM
I believe its my starter relay. Now there is a cable next to the kickstand that is leaking. How do I fix it.
Old Apr 26, 2012 | 08:07 AM
Le leaking? Le cabla next to le keekstand is le seedstand sweetch. Eetz all elektrik! There eez also a radiator drain hose that drips but is supposed to. Try bypassing le seedstand sweetch
Old Apr 26, 2012 | 08:41 AM
Huh lol
