New bike, basic info
Old Apr 20, 2011 | 04:15 PM
1n3's Avatar
1n3
Default New bike, basic info
I have no owners manual and was wondering what fluids need to be used and what the maintenance schedule is please. Also any advice on making sure the bike is in good order before I ride it for the first time.
Thank you
Old Apr 26, 2011 | 01:16 AM
Sixcell's Avatar
Thank you
Just make shure that there is right amount of brakefluid (dot4)
Check brakes (Pads & discs).
Check & fill coolant (ordinary coolant)
Check for wobble in wheelbearings.
Check for oil leak in front forks (change seals if neccesary)
Change oil & filter ( i use Castrol GT1 semi synthetic 10/40)
Intervall is about 7-10.000km.
Change air-filter once a year.
Grease up chain (i use motul o-ring lube every 3-400km)
Check air-pressure (i use 1.9bar in bwheel. 1.7 front)
Then get on bike, & ride!!!
Congrats on new bike... you wont wear it out if you take care of it.
-Six
Old Apr 26, 2011 | 09:41 AM
adrenalnjunky's Avatar
Thank you
You can download the honda manuals here:
F2 manual:
http://www.stephygee.com/F2manual.zip
But the copy of that manual found online everywhere that I have downloaded it doesn't include chapter 1 - which is the general capacities and bike specs sections that you asked about. I've bought a Clymer manual which is a little easier to follow than the honda manual - better pics - but you can download the F3 manual and use about 99% of the info there, as the F2 and F3 were very close mechanically.
F3 manual:
http://www.stephygee.com/F3manual.zip
And the Honda common motorcycle service manual:
http://www.stephygee.com/hondacommon.zip
Old Jul 18, 2011 | 09:41 AM
coldflood's Avatar
I know this is an old thread but I can't get the pdf to print ne suggestions?
Old Jul 18, 2011 | 10:29 AM
bdeljoose's Avatar
Default manuals
You can get honda shop manuals on ebay too.
Old Jul 21, 2011 | 06:19 PM
RicoLaw's Avatar
I found the honda shop manuals on ebay to be over priced. i went to Honda's website they sent me to another cite to buy a manual. it was much cheaper.
Old Jul 21, 2011 | 08:49 PM
coalminer frank's Avatar
Dex-Col coolant for Chevy aluminum radiators should be good for our aluminum infested engine etc. Rotella T6 Synthetic Diseal oil also. No friction modifiers or extended performance oil. Rotella T6 is good for wet motorcycle clutch. Any dot 4 brake fluid changed and flushed once a year. New fork oil and seals. Clean and regrease your swingarm and shock linkage. May be check steering stem bearings. And wheel bearings.
Old Jul 25, 2011 | 10:48 PM
MtnHonda's Avatar
Thanks for the info! I'm in the same boat and waiting on my manual to show up.
gwburress
Apr 7, 2014 01:21 PM
cybaster
Aug 15, 2010 08:09 PM
jp_greenville13
Apr 28, 2009 03:16 AM
LouSiffer
Jul 6, 2008 08:35 PM
CBRCorey
May 9, 2006 08:32 AM
