Need new caliper bolts!
Old Sep 1, 2012 | 03:50 PM
coalminer frank's Avatar
Default Need new caliper bolts!
I was going over my bike today. Installed fresh tires, cleaned calipers, and installed new pads on the front. When I mounted the calipers on the forks, I was torqueing to spec and noticed one of them just would not tighten. I stopped and backed it out and looked at it. It appears to be stretching to the point its going to break before it tightens. So................ where can I find new bolts, I looked on Ron Ayers and some of the others OEM dot coms and they all have the same picture that dont seem to have the bolts I need. Unless I am looking wrong. I dont see the bolt that goes through the fork tube into the calipers. Dont want to order the wrong stuff. Thanks.
Old Sep 1, 2012 | 07:44 PM
JankCibberf2's Avatar
run to the hardware store and pick up a bolt the same size
Old Sep 1, 2012 | 08:32 PM
I figured it out, I guess I couldn't see the trees because of the forest. +1 to ya JankCibber, we got an Ace Hardware 4 miles away with a crap lot of nuts and bolts etc.
Old Sep 2, 2012 | 12:46 PM
adrenalnjunky's Avatar
make sure you take the old bolts with you so you can match up proper hardness levels and whatnot. If in doubt, buy Grade8 at least.
Old Sep 2, 2012 | 12:52 PM
also - according to the service manual - those caliper bracket mounting bolts only should be torqued to 20 lb-ft.
Old Sep 3, 2012 | 03:11 PM
So I went to Auto Zone all they had was grade 10.9 metric. SAE was grade 8. Is the 10.9 ok or should I keep on searching. All the metric stuff was 10.9. The guy at the counter said they are about the same. What do you experts think?
Old Sep 3, 2012 | 09:45 PM
grade 10 is higher i believe and shoot its autozone so you know that that ****s strong enough for cars matey
Old Sep 3, 2012 | 11:50 PM
Well after digging around on line I finally found a site that explains bolt grades between SAE and metric. I appears SAE grade 8 is about the same as metric 10.9. Great! I just couldnt go with what the Auto Zone guy said. You never know what they might tell you just to get you to buy something.
o1marc
May 8, 2013 12:28 AM
Jaybird180
Nov 10, 2008 10:24 AM
Ruftags
Feb 15, 2008 07:32 PM
krash
Oct 29, 2006 02:30 AM
