caliper bolts
Old Feb 13, 2008 | 10:56 AM
Ruftags's Avatar
Default caliper bolts
I replaced pads all the way around. Do you guys use loctite on the bolts when u put them back in. The bolts that mount calipers appeared to have loctite on them before.
Old Feb 13, 2008 | 11:36 AM
specializedfuji's Avatar
Default RE: caliper bolts
when i replaced my lines and pads i just reinstalled them using the shop manual i have. it didnt say anything about loctite on the caliper bolts. ive been riding about a season without messing with them and i have not noticed anything wrong without loctite.
Old Feb 13, 2008 | 12:42 PM
some guy #2's Avatar
The manual says to use this specific Honda bolt that has the locking goop on it. I used loctite (blue) instead and no problems. At the very least it wouldn't hurt to use some. Torque them down right on top of that as well.
Old Feb 13, 2008 | 01:41 PM
charlos's Avatar
loctite is always a good idea on a motorcycle.
Old Feb 13, 2008 | 01:51 PM
slip_'s Avatar
Don't want that bike vibrating apart now lol
Old Feb 14, 2008 | 10:58 AM
Ruftags's Avatar
I kinda figured as much, but just wanted opinions.
Old Feb 14, 2008 | 11:39 PM
chpsk8er630's Avatar
I loctite everything just to be sure. I went for a long ride up the mountains and when I got off the highway after cruising for about 3 hours I let out the clutch lever and it came completely out because the bolt vibrated out somewhere on the highway but i was in 6th gear for a couple hours and didnt notice.
Old Feb 15, 2008 | 12:07 PM
sluijs01's Avatar
ORIGINAL: chpsk8er630
Same thing happened to me with my clutch, although I hadn't been in 6th gear for a while like you mentioned on your situation. It was probably just negligence on my part for not checking periodically. Either way the bolt about popped out on me.
Old Feb 15, 2008 | 07:32 PM
TBFGhost's Avatar
The F4i I bought must have the same problem with the clutch lever lol, they guy put another bolt in there but it was NO WHERE NEAR the correct one.
o1marc
May 8, 2013 12:28 AM
coalminer frank
F2 Tech
Sep 3, 2012 11:50 PM
Jaybird180
Nov 10, 2008 10:24 AM
krash
Oct 29, 2006 02:30 AM
