Is my engine toast from this 1 little piece?
dude, BUMP START! works like a champ. no need to get a new motor cause the button start dont work. listen... Choke=on, ignition=on, put it in first, pull the clutch in, get off the bike and run next to it until you are running as fast as you can with the bike and hop on and dump the clutch at the same time. works like a champ. doesnt hurt to twist the throttle a little as you dump the clutch. also, sometimes it takes more than one try. just do that and you will have saved yourself 300 bucks. trust me, your bike will clutch start.
IMO that's a terrible suggestion. Yeah, it'll work. I had to do it a few time when my R/R took a dump. Its a pain. Its obnoxious. Its somewhat embarrassing.
I'm sure mine wasn't the only vehicle in that lot that needed to be push started..
