Lost all electrical power, stranded on highway
Old Mar 22, 2010 | 11:45 AM
  #21
FuzzyWuzzyBear's Avatar
Still need help on this mysterious black wire, the "main switch power lead." On the wiring diagram, it shows one of the grounding wires at the mounting bracket as Gr/Bl so that must be it, but how do I know which one? And, as before, do I splice this both into the bracket into the R/R, or what?
Tony emailed me back saying, "If you can't find the black wire, find main power wire from the ignition switch that has power when the ignition is on and connect it to that."
I'll look at the wiring diagram from the service manual when I get home, but is anyone familiar with the main power wire from the ignition switch?
Old Mar 24, 2010 | 06:54 PM
  #22
Sand.Man's Avatar
I just got mine in the mail, I'll be tackling this soon and will post my results for you.
Old Mar 24, 2010 | 07:00 PM
  #23
I ended up never being able to find the black wire. Tony advised me to connect the R/R's black wire to the main voltage wire coming from the ignition wire. I traced it on the wiring diagram to being the solid red wire coming off the main relay (housing the main fuse), so I spliced it into that.
I ended up not being able to test if this is indeed the correct wire because my bike hasn't started due to an electrical short elsewhere in the harness but I would appreciate any feedback you have after you install yours.
Old Mar 24, 2010 | 07:09 PM
  #24
Sand.Man's Avatar
Yeah for that black wire there is no specific wire needed.. You just need a wire that only gets power when the ignition is turned on.
raylee
Oct 9, 2012 09:27 PM
bikerboy46032
Oct 7, 2010 10:16 PM
RBarker63
Jun 7, 2010 07:14 PM
lakaiguy
Feb 15, 2009 04:49 PM
Greg2561
Jun 5, 2006 07:10 PM
