Please help my electrical issues bc im lost
ill start from begining to end.
2001 CBR600 f4i
> long winter, battery died
> had to move bike to different house so i charged the old battery and managed to get it going.
> bought new battery today
> installed new battery today
> had a hard time getting it to start but it finally turned over
> ran for about five to seven min then died
> now it is acting like the battery is dead again
> NO neutral light
> sometimes headlight will flicker
> i can only hold the start button for about 3sec then all power is lost
Can anybody help me out?
2001 CBR600 f4i
> NO neutral light
Did you charge the new battery before putting it in? New batteries need to be charged too. Check the voltage on the new battery.
If the battery is good check the connections on the harness, especially the headlight since that's a possible symptom. Good connections, check the starter button and kill switch connections. Sometimes the solder breaks loose on there. And make sure the battery connections are properly tightened down as well
stator might be dead.....
Should be a test similar to this
https://cbrforum.com/forum/general-tech-stickies-106/how-diagnose-charging-system-51691/
