Just Can't Get my Jetting Right
First off thanks to all who have helped me thus far, without your help I wouldn't be as close as I am. Anyway, here's whats up. The bike has a 4-1 'race' header and shortened pipe with almost no packing or baffling in it (sounds almost like a straight pipe), and a stock air filter. It has a dynojet stage 1 jet kit in it; glued one of the slide holes shut on each slide (per dynojet instructions), has 126 mains, and the needle clips on the second spot from the top.
It runs perfectly from idle to 8k then hits a flat spot where if i play with the throttle (alternating from like half to full) I can get it to like 9.5-10k where from there to redline it pulls real hard. From all my experiences thus far, the 8-10k prob seemed like a rich problem, so I put on a k&n filter to try it out. Idle-8k stayed perfect but from 8-redline it sputtered and barely ran (guessing way to lean?). My next move I think is to put in 124 mains with the stock air filter and try that. What do you guys think? BTW idle-8k is real perfect, I just rode this sucker 630 miles in 2 days averaging 70-80mph getting 46mpg. Not bad |
Those who have seen my previous posts know I've pulled these carbs 7-10 times. I've tried stock needles, mains as big as 145, all different combos. Turned out one of my main problems was my absence of a heat shield. I made one up modeled after the stock one and it changed everything. They're real important to prevent turbulence under the air box
I can't remember where we left off in any other threads, but 124 will be too lean on top with a paper air filter, and of course, even more so with a K&N.
The top-end (main jets) have to be dialed in before perfecting the other ranges, though if your real darn close with mid-range and low speed/idle, then once you get your mains right, you might not have to make much adjustment of those (jet needle and pilot settings). With 126 mains, race header, and essentially a straight-through exhaust, I would expect 126 to be too lean as well, especially bearing in mind that the stock jets are 135. Personally, with the K&N installed, I would leave your jet needles alone for now, set your fuel screws to 2 1/4 out, and start working from 138 mains... if 138 gives you a nice hard pull from about 7500 to 13,000, then try a 140, if it then gets worse, then you know you're going in the wrong direction, if it gets even better, then repeat with 142 mains (both of my bikes are on 142 mains, with race headers and shortened cans, and they run like mad). I cannot stress enough, that you need to focus on the mains first, completely ignoring other ranges, so long as it idles and runs decently in the lower ranges, THEN start working on the circuits below, i.e. needles and pilot screw settings... I'm sure I mentioned this before, but it is crucial to dial things in "from the top, down", or your're going to work in circles. Another thing worth mentioning, is that if you're still doing all this testing on the same plugs, you need to at least pull and inspect them, in case they've been fouled-out during previous running... clean or replace them, so you KNOW you've got good plugs when you test the bike on the road. Just out of curiosity, do you know that this motor has good compression in all four cylinders, and with good plugs in, have you ever done spark tests on all four, to verify you're getting a good blue/white spark? With any other issue at play, this will just get totally confusing. |
Originally Posted by JNSRacing
(Post 1250164)
The top-end (main jets) have to be dialed in before perfecting the other ranges, though if your real darn close with mid-range and low speed/idle, then once you get your mains right, you might not have to make much adjustment of those (jet needle and pilot settings). With 126 mains, race header, and essentially a straight-through exhaust, I would expect 126 to be too lean as well, especially bearing in mind that the stock jets are 135. Personally, with the K&N installed, I would leave your jet needles alone for now, set your fuel screws to 2 1/4 out, and start working from 138 mains... if 138 gives you a nice hard pull from about 7500 to 13,000, then try a 140, if it then gets worse, then you know you're going in the wrong direction, if it gets even better, then repeat with 142 mains (both of my bikes are on 142 mains, with race headers and shortened cans, and they run like mad). Correct me if I'm wrong, but if I recall from your threads, you're using factory pro needles right? How do those differ?
(Post 1250164)
Another thing worth mentioning, is that if you're still doing all this testing on the same plugs, you need to at least pull and inspect them, in case they've been fouled-out during previous running... clean or replace them, so you KNOW you've got good plugs when you test the bike on the road. Just out of curiosity, do you know that this motor has good compression in all four cylinders, and with good plugs in, have you ever done spark tests on all four, to verify you're getting a good blue/white spark? With any other issue at play, this will just get totally confusing. Thanks for the help man you always have good advice. If worse comes to worse, I'm putting in stock slide springs, stock needles, 135 mains, and a stock header and starting from there. |
Originally Posted by Ls1Mx5
(Post 1250168)
Maybe I didn't emphasize this in my first post but the 126's and the 124's I intend to use are in terms of dynojet numbers. The DJ 126's are the same size as keihin 135's and DJ 124's are keihin 132's.
Anyway, I did not know that about DJ mains, and no surprise, because I've always used Factory Pro stuff, and I only use Keihin main jets, for consistency, though Factory Pro does claim that their jet size designations are to be used for direct replacement of Keihin jets of the same size.
(Post 1250168)
...keihin 140 mains and DJ needles gave me a perfect 7-13k pull.
If 140's were giving you a perfect pull, then get back to those - did you by chance also run 138 and 142, and found 140 to be "the sweet spot"? Anyway, mains first, so if 140 gives you a rocketing from 7,000 to 13,000, then put 'em back in, and forget 'em... now, work on your needle jet circuit.
(Post 1250168)
Also, I've found that the dynojet needles significantly change the 7-13k operating range when compared to stock needles. As an example, when I didn't have the heat shield in, keihin 140 mains and DJ needles gave me a perfect 7-13k pull. When I tried stock needles, it was so lean it would barely run past 10k.
Correct me if I'm wrong, but if I recall from your threads, you're using factory pro needles right? How do those differ? So, ride the bike, and see how the needle position feels, and take your best guess at whether you're rich or lean, from 5K to 7K. This is not easy, and if you're not well versed in "feeling this out", you might guess wrong, but if your change makes it worse, just go the other way until you stop improving with each change. It's true that the stock needles could be more of a challenge, and could take a lot of shims to get things right, that's why the aftermarket needles have the variable clip positions, and you can still use/lose a shim, in conjuntion with a raising or lowering of clip position, to make smaller changes. I can't make any comparison to the DJ needles, but I hear they are slimmer, with regards to the diameter/taper, which allows a bigger "hit" of fuel when the slide first starts opening. Some have complained about the "driveability" of the bike, due to this slimmer taper, and most of those that I've read about, that went from the DJ to Factory Pro Needles, were pleased with the change... in short, I've heard a lot of complaints about DJ needles, and I don't think I've heard any about the Factor Pros. Yes, I use Factory Pro needles, and they don't seem that far removed from stock, with regards to the overall diameter and taper, but they seem to have a smoother tip, which would allow a smoother flow of fuel perhaps - the main advantage to me is the ease of adjustability. Carb tuning can be a royal pain, but if you only make one change at a time, start with the main circuit and work your way down, and stay consistent with other aspects of setup (same header/can, same air filter, good plugs at all times), it will work out eventually! |
(Post 1250192)
Now that is just annoying!!:icon_doh: Why in the world would they do something so confusing?!? :icon_doh::icon_doh:
(Post 1250192)
OK, now this is what we need to be focusing on, getting your mains correct first. Now that we got the cross-referencing of jet sizes out of the way, what you're saying above is close to what I was suggesting, which is working in the range of 138 to 142 (Keihin sizes :D).
If 140's were giving you a perfect pull, then get back to those - did you by chance also run 138 and 142, and found 140 to be "the sweet spot"? Anyway, mains first, so if 140 gives you a rocketing from 7,000 to 13,000, then put 'em back in, and forget 'em... now, work on your needle jet circuit. 135s are too rich for the stock filter but too lean for the K&N. It stands to reason that 132s with the stock filter then should be right.
(Post 1250192)
By the way, how many positions are on the DJ needles?
(Post 1250192)
(Post 1250192)
With the DJ 126s it pulls hard from 9000 and up, but you have a flat spot around 8000. This is the needle transition point. It sounds like a lean spot rather than a rich spot. Try raising your needle by moving the clip down one or even two slots. If it gets worse then you need to raise your clip up to lean it out. I lean (no pun) towards the lean condition, as it runs crisp and clean up to 8000. Tuning is fun without an AF meter. Old school
Originally Posted by gpfan1
(Post 1250331)
Well juggling in my head whether its rich or lean from 8-10k a lightbulb went off. Why don't I run it with the choke on and see what happens? Am I right? If with the choke on it pulls from 8-10k I will have discovered it's lean right?
Pulled a lot better with the choke on, gonna lower by 2 positions and try it
