high idle problem
#31
What that means, is whatever the seller is interpreting it to mean, which is not clear... it could be he's just saying there are no throttle cables, but I would message the seller, and get confirmation on this.
#33
Meh, we all have bone-head moments... see one of the last posts on my Phase 2 thread, like third from the last, talk about bone-head moments! I'm not qualified to go back out to my garage again just yet!!
#34
alright sorry I been leaving you guys hanging haha. I just started my second year of college this past monday, but I finally got around to it and ordered that complete set for $120. I figured it would be in my favor to have a pretty much complete and a complete set to work with, rather then a complete, but "boogered" (as you all like to say), and incomplete set. Hopefully no one was confused by my terrible sentence structuring
Anyway I am looking at next thursday for everything to be in. So next weekend I will be ceramic coating my headers, exhaust can,and possibly midpipe. I might also shorty my pipe but I havent decided yet. I will also be putting in the new carbs and attempting to tune them. I understand the little screw adjustments and I am researching on carb syncing. Shop I went to wants $250 for a carb service which is just stupid to me.
I was just wondering if you guys know where to pick up those tools to adjust the pilot jet screws?
Does anybody have an opinion on the homemade sync tool made with clear tubing and atf? I know there is a bunch of writing about it and I have been reading it! I was just wondering if there is any updates on possible dangers with using the atf method vs. a gauge. Last thing I want is a bunch of atf getting sucked into my new carbs and having to buy another set.....
thanks again to the guys sticking around and helping me out (you know who you are).
Once I start the work I will take pictures and videos of before after and during. (pipes and carbs). hopefully then you will at least have a little bit of entertainment out of this.
#35
#37
#38
factory pro wanted $15 plus shipping for the tool. The shipping online is $12 nation-wide, and on the phone I was told they could ship it for something like $5. I am still looking for a cheaper tool. I should also mention that is only for the bit; not the entire screw driver or whatever it is they give you with the kits.
#39
Thats not too terribly bad I don't guess. If you happen to have one of those finger drivers, like
its not too hard to turn the bit when the carbs are installed. The motion pro bit itself is only 2.99 from jetsrus.com not sure about shipping though, its here.
If your looking for other more um, mcguyver ways, I've read .223 shell slightly flattened on one side works, I just took a piece of copper tubing I had left over from an ice maker installation and flattened a side of it, worked perfect and was free, thats two wins in my book
#40
thanks man, what I ended up doing was backing them out with a bent retainer clip and then I put a slot in each of them so I can use a flat head screw driver. Took like half an hour to do it but it wasn't that bad.
I looked for a casing but the only ones I found around the house were too big.
Also I just installed the carbs today. It took a while to get everything cleaned and swapped over, but now the set I bought is pretty much brand new.
When I adjusted the pilot adjustment screw on each caarb i took it out 2.75 turns because I have a high flow k&n air filter (don't know if that really makes a difference but i hear it does), and an aftermarket exhaust that I cut into a shorty.
I ran into a problem! When I started the bike it was running but I could tell that it sounded weird. BUT when I looked under the tank the petcock was spitting out fuel everywhere! This did not happen before I changed the carbs.
Is it possible that the carbs are out of sync and number one cylinder is pulling too hard on the vacuum petcock?
Did i go too far by adjusting the screws 2.75 turns out?
thanks for any help guys
