headlight fandango
Old May 9, 2011 | 11:08 PM
jdub22's Avatar
Default headlight fandango
ya so the cliche one thing after another.... rode my motorcycle today and when I pulled in the garage I must of hit the highbeams and the headlight don't work now. I tested my blinkers and they work besides that the right one was blinking extremely fast for a few seconds. I didn't have time to look at it because I had to come to work. Im thinking I probably blew a bulb. But also thought it might be a fuse. Don't know since this is my first bike. There is a box on the left hand side of the frame while sitting. Is this where the fuse for it would be?
Old May 9, 2011 | 11:16 PM
jk72180's Avatar
its on the right side
Old May 10, 2011 | 03:07 AM
jdub22's Avatar
well it may be what im saying is there is a box next to the left fork that says fuse
Old May 10, 2011 | 07:30 AM
jk72180's Avatar
yes its a little black box about 1 x3 marked fuses has 3 or 4 fuses in it thier is also a 30 amp main fuse in front of the battery if the fuses are good try looking in the run stop switchthier are 3 wires the far right one kills the headlight for starting and likes to come unattached
Old May 10, 2011 | 09:04 AM
adrenalnjunky's Avatar
High beam and low beam on the stock headlamp pull power from the same fuse - if the lo-beam is working and High beam isn't, it's either the bulb, or the switch.
Old May 10, 2011 | 10:38 PM
jdub22's Avatar
lol took the headlight cover off and found the ground disconnected. so put it together and she's good to go thanks for the input.
cmartino88
Aug 1, 2012 06:39 AM
papa wheelie
Jul 20, 2011 11:16 AM
Davidth93
Jul 16, 2009 12:22 AM
cyber00677
Aug 3, 2007 03:57 PM
