F3 petcock on a F2?
Old Jul 6, 2010 | 10:29 PM
DopeBoy239's Avatar
Default F3 petcock on a F2?
I was told it will work and it's better because it doesn't use vaccum. Is this correct?
Old Jul 6, 2010 | 11:41 PM
nitrodude's Avatar
Yes it will.
You wouldnt by any chance live in FL would you? Think i might of just met you earlier today lol
Old Jul 7, 2010 | 07:56 AM
Frank_F2's Avatar
The purpose of the vacuum line turn off fuel flow when the engine is not running. The F3 has a fuel pump so it doesn't need a vacuum petcock.
If you use the F3 petcock and the bike falls over or you crash, the bike can not turn off the flow of fuel and it will empty the tank on the bike and ground.
If you are having problems with the vacuum side of the petcock just buy the "coverset, petcock" (as Honda calls it) and replace it. Problem fixed.
Old Jul 7, 2010 | 09:13 PM
DopeBoy239's Avatar
Originally Posted by nitrodude
Yes it will.
Hahaha small world. The f3 petcock will bolt on and get fuel to the carbs but I think having a f3 petcock would be the same as having my bad f2 petcock. Constant flow to the carbs. Not what I want. I picked up a f2 petcock today for $30. It works great so I'm set!
Old Jan 10, 2011 | 09:51 PM
kinglee86's Avatar
i have a f3 petcock on my f2....where do i plug vacuum hose from carb 1 since theres no hole on petcock??
Old Jan 13, 2011 | 04:05 PM
gpfan1's Avatar
Just cap off the port from #1 with a vacuum rubber cap. Or stick a golf tee in the end of the vacuum line. The open line will cause the bike to run rough and idle badly.
Old Jan 14, 2011 | 07:45 PM
kinglee86's Avatar
ok
1992 gsx600f
Mar 10, 2011 12:57 PM
jestr
Feb 15, 2009 11:06 PM
tazshido
Feb 25, 2008 01:56 PM
cbrboyze
Nov 9, 2007 07:54 AM
