F2 Throttle Help
Old Apr 27, 2010 | 02:00 PM
quartazz's Avatar
Default F2 Throttle Help
I recently cleaned my carbs and I was wondering has anyone come up with a quick/easy way to reconnect the throttle assembly, because its definitely not a fun task to take on.
Old Apr 27, 2010 | 06:12 PM
cristopech12's Avatar
no my friend, my easy way was put first the throttle cables but not tighten until you reinstall on the admission tubes, but was annoying for all the time.
but don't worry relax, do this thing calm because if not you may be messed something, have fun.
Cris
Old Apr 28, 2010 | 09:20 AM
dustinjklee's Avatar
There is a certain way you have to do it. Its very easy and will only take like 3 seconds. You dont put your throttle cables in the brackets that hold them until youve secured them in the part that opens all the carbs at one time. You loosen the nut up quite a bit then you slide the cable in between the 2 carbs and loop it into the little flap then you pull the cable back and put it into the bracket. After loosening the bracket that holds my cables snug it only takes me litteraly 5 seconds to get them undone.
Old Apr 28, 2010 | 10:48 AM
quartazz's Avatar
i got the carb part down I am then also referring to getting them installed on the hand twist.
Old Apr 28, 2010 | 11:42 AM
Im pretty sure you have to keep the throttle cables loose and then put them on the tube
darikfrye91
F2 Tech
Jan 16, 2012 10:55 PM
cbr6rider
Apr 20, 2011 08:57 AM
Gacho
F2 Tech
Apr 6, 2011 04:13 PM
zellster
Sep 29, 2010 02:42 AM
