f2 stock float level?
Old Jun 4, 2013 | 10:20 AM
the600's Avatar
Default f2 stock float level?
Can anyone tell me the stock float level for a 94 f2? I can't seem to locate that info....thanks!
Old Jun 4, 2013 | 10:44 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
That's because the floats and tangs are both plastic, and are not adjustable, like with some carbs.
Just inspect the floats for damage, and you'll be good, if you really want some assurance regarding the level, just check for consistency in level from one to the next, but if they are undamaged, you should be fine!
Old Jun 5, 2013 | 11:30 PM
squale147's Avatar
July 2013 ROTM
Originally Posted by jnsracing
that's because the floats and tangs are both plastic, and are not adjustable, like with some carbs.
+1000
Old Jun 6, 2013 | 12:38 PM
the600's Avatar
Thanks! That explains it! I will do a good clean and inspect and go from there!
Old Jun 18, 2013 | 06:34 PM
gpfan1's Avatar
I had my bike stored away for several years and the plastic floats bent under their own weight and wouldn't seal with new needle valves. I got new ones and the problem went away. F2 floats only need gravity feed, so they are relatively light pressure. When using a remote tank for tuneups, I had to make sure it wasn't too high above the bike, or it would over power the floats.
gator215
Apr 10, 2010 08:00 AM
pablohoney
Jan 27, 2010 10:04 AM
MrHorsepower
Jun 25, 2009 06:00 PM
furious82
May 18, 2005 08:32 AM
