Dripping Carbs
Old Apr 29, 2010 | 02:02 PM
lanceam24's Avatar
yes i tried that gasketmaker junk at first. first of all its messy as hell and it doesnt seal as good as the true rubber type gasket. one guy made a good point and mentioned that i could just buy a whole new set of used carbs on ebay for around the same price as 4 of the gasket sets...
Old Apr 29, 2010 | 03:30 PM
C Average's Avatar
Well has Anyone ever successfully used gasket maker. Because Ill do that **** with diligence to save me from buy gaskets if it can be done right
Old Apr 29, 2010 | 04:17 PM
wiltse's Avatar
Default hey
I used this stuff from permetex i believe it worked really well just put a light film on top of your old gasket.
PS make sure you look on the back of the tube or wrapping to make sure it is the one that is resistant to petroleum products.
Old Apr 29, 2010 | 04:59 PM
C Average's Avatar
right on. I new someone out there could do it right. Im gonna attempt it. worse case i clean them again and fork out for the oem
Old Apr 29, 2010 | 05:00 PM
C Average's Avatar
can a leaking carb cause your bike to run lean ?
Old Apr 29, 2010 | 08:31 PM
halffast1g's Avatar
it would make sense if more fuel is exiting the carb than entering the cylinder
Old Apr 29, 2010 | 08:53 PM
cbr900racer77's Avatar
Only if it's a stream the size of your thumb. Gas lost via the leak is quickly replaced. Did you confirm it's running down the sides of your bowl? If it isn't, it's the Oring on the drain screw like mentioned before and not bowl gasket. I've used Hondabond on a bowl gasket before with success. Like someone said, be careful that it doesn't run down inside. But make sure that's what it is first.
Old Apr 29, 2010 | 10:06 PM
C Average's Avatar
yeah cbr9 Its running down the sides. on 3 of them. Sucks. and its running lean even after i tried 2 3/4 out
Old Apr 29, 2010 | 10:22 PM
C Average's Avatar
Also. Has Anyone tried to cut their own gaskets out on the sheets of gasket rubber?
Old Apr 30, 2010 | 01:10 AM
lanceam24's Avatar
i jus forked out $69 for the other 3 sets shipped... o well, at least i know im getting what i need
