dp clutch problems
Old Jun 23, 2013 | 01:14 PM
itsahurricane's Avatar
Default dp clutch problems
so i installed a new dp clutch kit in my 94 f2 and somethings not right. both the lever and the other side of the cable are adjusted to the max and it barely is enough.. its hard to find neutral and it feels like the clutch is still grabbing a little when I hold the lever in. also hearing a little chatter when im going down the highway.if I pull the lever in just a little the chatter goes away.. im so lost!
Old Jun 24, 2013 | 12:21 AM
squale147's Avatar
July 2013 ROTM
id go back in and check it out...did you aline the punch marks on the inner and outer hubs?
richardandrews
Mar 27, 2013 04:03 PM
asides
Mar 30, 2011 11:29 AM
lsybert
Jun 25, 2009 11:07 AM
881000F
Aug 11, 2008 06:42 PM
Sparkylyleusa
May 25, 2007 08:02 AM
