clutch problems
Old Aug 11, 2008 | 06:13 PM
881000F's Avatar
Default clutch problems
Hey fellow cane lovers I'v been riding and restoring and have run into a problem. My clutch lever has lost its tension when I pull in on it and when bike is running and in nutrel and i pull in on clutch and try to put in 1st the bike jumps and dies I have replaced oil in clucth master cyliner and there is no change. HELP PLEASE!!!!
Old Aug 11, 2008 | 06:21 PM
BayAreaRider's Avatar
Default RE: clutch problems
Sounds like you got some air in the line. You have to bleed the some of the newhydrolic fluid through the bleeder. It takes quite a few pumps if you're pumping the lever. With fluid in the resevior, you can also keep the lever engage with a clamp/rubber bands for a few hours the let air bubble up. Then try bleeding again until pressure returns.
Old Aug 11, 2008 | 06:42 PM
weekendrider's Avatar
remove the master cover thentry removing the slave cylinder and pushing the piston right in.Then refit it and then 1/4 pump it till it loads up. If that dont work your master cylinder might need a kit. One more thing put your bars on right lock for maxamim fluid and dont fit the master cylinder cover till you have clutch. Put wet rag under cylinder for fluid spills
richardandrews
Mar 27, 2013 04:03 PM
asides
Mar 30, 2011 11:29 AM
Biker_Angel13
Oct 10, 2010 10:27 PM
lsybert
Jun 25, 2009 11:07 AM
Sparkylyleusa
May 25, 2007 08:02 AM
