Confused
Old Dec 27, 2012 | 01:37 PM
subyman1440's Avatar
Question Confused
So where exactly is the temp sensor wiring supposed to plug into? Like out from the sensor to...where? Because right now, it's going from the temp sensor to another sensor to the left of it. It seems like someone cut it, then spliced it.
Old Dec 27, 2012 | 02:29 PM
CorruptFile's Avatar
June 2013 ROTM
Well there is a temperature sensor, and there is a temperature switch, which controls the fan. Not sure if they are directly connected though... Pics?
Old Dec 27, 2012 | 03:32 PM
Duck62's Avatar
The temp sensor is right above the thermostat housing. The switch for the fan is mounted on the radiator.
Old Dec 27, 2012 | 04:50 PM
adrenalnjunky's Avatar
this would be a good time to look at a wiring schematic with the color of whatever wires/plug you're confused about to figure out what's what.
Old Dec 28, 2012 | 12:24 PM
It seems like somethings wrong. The two sensors are spliced to each other.
Old Dec 28, 2012 | 01:30 PM
The plug on the right of the pic is your thermo-sensor (engine temp gauge sensor), the one down on the block is your oil pressure sensor.
They don't tie together in the factory wiring harness. The oil pressure signal wire runs only up to the gauge cluster (oil warning light).
The temp sender wire runs only to the temp gauge in the stock wiring harness. Since they both only conduct the ground signal when open, or the engine heats up - having them connected together like that is pointless.
ricwhy33
Oct 4, 2009 11:33 PM
slamd_f2
Aug 7, 2009 11:50 AM
Speedin4Fun
May 14, 2009 09:55 AM
lilbear777
Jan 15, 2008 09:54 AM
Brando159
Aug 23, 2006 03:41 PM
