So confused
Old Aug 21, 2006 | 11:44 AM
Brando159's Avatar
Default So confused
Alright this is weird as hell so my bike got knocked over one night so i thought i would change my plugs which you should do right...
so i get the iridiom ngk
put them running great till i hit the freeway then i cant hoold aa steady speed i wanted to boggg intill i gave full throttle then i would stop it was weird .... but its fine around town..?? any suggestion i clean throttle bodys and everything already feels like im losing fuel or something never did till i put these plugs in could it be running to rich....????
94 cbr 600 f2
so confused
Old Aug 21, 2006 | 01:31 PM
mikequinn's Avatar
Default RE: So confused
Did u set the gap correctly???
Old Aug 21, 2006 | 07:15 PM
bindelsf2's Avatar
is a fuel line kinked??
fuel selector opened all the way?
fuel?
overflow hoses kinked?
Old Aug 21, 2006 | 07:26 PM
Brando159's Avatar
would the fuel line kinked only cause at 60-70 mph because my low end is fine....its just high end ??
Old Aug 21, 2006 | 08:02 PM
bindelsf2's Avatar
no it wouldnt, it would be short on fuel as soon as you got on the throttle hard. huh..... i cant think of what it could be.
the only other thing i can think of is are the jets set improperly?
Old Aug 21, 2006 | 10:32 PM
mikequinn's Avatar
If it was ok before you changed the plugs (which I Assume it was, as you didn't state differently), then there's nothing wrong with the fuel side of it,
why does everyone look to the imposible 1st??????????????????????????????????????????
i've put irridium plugs in loads of CBR from standard and had no problem but you have to set the gap correctly IT IS SO IMPORTANT!!!!
there is no such thing as pre set plugs as the so called shops tell you
what happens if they drop 1 in the shop while packing stocking them
Old Aug 21, 2006 | 10:44 PM
bindelsf2's Avatar
well when i change the plugs i shut the fuel valve off and take the tank off. (because i will clean out the airbox and filter too) when you put the tank back on it is totally feasible to pinch a line hence the bike getting fuel at low speeds but when it needs a lot of fuel it not being there.
Old Aug 21, 2006 | 11:41 PM
poorfish's Avatar
I had the same problem with mine. Check your wire connection. Make sure they snap in tight. If not it will run weird. On mine it was the #4 plug wire that seemed tight, but was not. Good luck
Old Aug 22, 2006 | 07:06 AM
mikequinn's Avatar
You never said you had the tank off [:@]
you don't need to take the tank off to change the plugs,
Why does everyone cause so much work for themselves when working on their bikes, if you get the correct spark plug socket all you need to do is remove the small side inspection pannels on each side,
Old Aug 22, 2006 | 10:15 AM
Brando159's Avatar
i think i found my problem i had a hole in the main fuel line not to big.. it was right were the clamp was.. so i hope thats my problem no i took the tank off to clean air flilter and had to move some stuff out of the way from previous owner messing with.......
so ill keep you guys informed i havent had a chance yet to fix it tonight i am working on it
