Clutch problems
Old Jan 6, 2013 | 11:27 AM
USMC_Arango's Avatar
Default Clutch problems
Ok so i put in a new clutch lever because my old one was hanging loose, when this one was put in i was expected it to be tight and what not but that wasn't the problem apparently there was another problem, my clutch cable was messed up that's why it was so hard to pull in and i never knew what a real clutch lever was supposed to feel like till after my mechanic put some spray to loosen it up but he said i still need a new cable. so not only am i going to get the cable i would also like to know from someone here why is my clutch slipping? i know it's not me or anything it's the bike because let's say i'm in 3rd gear i go to 4th then it revs supper loud and makes this pin in a bottle noise but it still goes to 4th i've realized? what do i need to get to keep it from slipping?
Old Jan 6, 2013 | 02:08 PM
MadHattr059's Avatar
First get the clutch cable replaced and adjusted properly.
There should be about 1/4-3/8" of slack in it, when it is properly adjusted.
Then check to see, if the clutch is still slipping.
If it goes away, your cable may have been hanging up and/or
improperly adjusted, hence, may have kept the clutch from fully engaging.
If it doesn't go away, then your clutch is worn and needs,
either new springs or plates (or both).
Hope this helps, Ern
Old Jan 6, 2013 | 03:42 PM
Alright thanks, and yea i'm getting that cable asap i hate having my clutch ever dangling and hard to pull in that spray is wearing off already lol
richardandrews
Mar 27, 2013 04:03 PM
asides
Mar 30, 2011 11:29 AM
lsybert
Jun 25, 2009 11:07 AM
881000F
Aug 11, 2008 06:42 PM
Sparkylyleusa
May 25, 2007 08:02 AM
