Carb sync problems
Old Aug 8, 2011 | 05:25 PM
sk8er406's Avatar
Ill try that and see if I can get any response.....I bought the motion pro sync tool
Old Aug 9, 2011 | 08:29 AM
MikeInCtown's Avatar
Just remember the sync tool is to balance the butterfly openings. You will also need a very sensitive tach to properly adjust everything. Once the carbs are balanced then you need to go through and adjust the mixture screws to the proper specs based on RPM. 4 turns out is the mixture screws. Not sure if your new tool will help you with your problem. I do know specs are something like 2 turns out.
Old Aug 9, 2011 | 12:41 PM
sk8er406's Avatar
I understand all of that but it seems that 4 turns out is a bit much like its compensating for another problem.
cookml22
Apr 1, 2013 04:12 AM
compster
F2 Tech
29
Jun 5, 2012 12:28 PM
hss2010
Feb 19, 2012 01:30 PM
LMP1327
Dec 25, 2009 10:42 PM
My89CBR600F
Sep 20, 2006 01:30 PM
