can't get my stator cover back on
Old Oct 2, 2011 | 12:05 PM
coldflood's Avatar
Default can't get my stator cover back on
any advice?
Old Oct 2, 2011 | 01:45 PM
JankCibberf2's Avatar
Lol match the holes up and don't over torque the bolts
Old Oct 2, 2011 | 01:53 PM
coldflood's Avatar
I can't get it to sit flush
Old Oct 3, 2011 | 03:14 PM
buickid's Avatar
Whats holding it up? Warped? Get a new one.
Old Oct 3, 2011 | 03:21 PM
estate4life's Avatar
February 2012 ROTM
I had the same problem with my RR, just go slowly, make sure all the pins & starter gear is place on correctly & flush...double check all screw is snuggly fasten...especially the one that holds the stator.
It's tricky, but be patience....keep trying...
Old Oct 3, 2011 | 03:24 PM
February 2012 ROTM
Oh...did you clean out the old gasket? I used a razor blade (carefully remove the old gasket) the clean/scrape using my fingernails...you gotta get ALL old gasket off
Old Oct 3, 2011 | 03:30 PM
February 2012 ROTM
Then when stator cover is in placed, all pins & holes line up straight, hand screw on all bolt, then use tool to screw in bolt ( rotate ) just do 1 or 2 turns and then move to the opposite side. You want to screw on each bolt little at a time. You don't want to focus on one screw at a time. Just one turn, then move to next bolt, go thru all of them until cover sits flush. takes patience, good luck and don't over torque
Old Oct 3, 2011 | 08:23 PM
coldflood's Avatar
Thanks, I'll let you know if I snap another fastener
Old Oct 3, 2011 | 11:49 PM
JesseAwesome's Avatar
Old Oct 4, 2011 | 09:42 AM
adrenalnjunky's Avatar
