Cali Bike-camshaft replacement
Seems I have purchased a 1994 California spec bike. Assuming this due to the evaporative cannister. Apparently the cams are different and reduce the power output appreciably. Thinking of picking up some used cams off ebay. Wondering if anyone has experience with or knowledge of such a change?
imo to make your cali bike to a 49 state bike would be alote of work..cams,jetting,cdi box,cam timming, air pump,evap system,pair system,..changing the cams to a 49 state would be the best thing to do as for the the cam specs for the cali model are .220 duration .263 lift to the 49 state cam specs are .325 lift .235 duration...that would at least put you at the same hp as a 49 state bike...the other things like evap,pair,system you could just take off the bike..
