Cable routing help.
Old May 11, 2011 | 07:25 PM
antatious's Avatar
Default Cable routing help.
I went through my entire clymer and it doesn't have one good picture or diagram where I can see how my clutch, choke, and throttle cables are routed through/around the frame. I tried the search function on here, and tried searching google with no luck. I even tried finding some close up pics as well- no go.
If anyone can help me out, it would be very appreciated. Maybe one of you readers has their fairings off at the moment and would like to snap a quick pic, I would love you. Or perhaps, you are a genius at describing things. I would return the love with pictures of my bike almost all put back together
Thanks a lot
Old May 12, 2011 | 05:23 AM
SmokinJeff's Avatar
Hope these help. From an F3 manual. Cheers
Old May 12, 2011 | 06:05 AM
antatious's Avatar
Wow. You are so awesome. I didn't even think to use an F3 manual. As promised, when I get home from class today i'll post some progress pics of my bike coming together.
I WANNA RIDE!
Old May 12, 2011 | 04:46 PM
Bently600's Avatar
Those ARE great pics of the cable routing. time to go find an F3 manual to download... stupid F2 manual has nothing that easy to understand.
Old May 13, 2011 | 08:34 AM
antatious's Avatar
Well, I said i'd post a pic. But with the quality of the picture, it's barely worth posting. Anyways, here she is mostly back together for the first time on her own two wheels after a long winter. I went through the entire bike and quite literally, the only thing in NEED of being replaced, was my pro link suspension bearings. They were a little rusted out. This is after 24k miles. Everything else was in great condition, which really surprised me... And didn't at the same time considering it's a Honda.
Oh, and my clutch cable has a few torn strands. I will be replacing that.
Only things that still need to go on, are exhaust, wiring harness, rear brake, and foot pegs. Oh and the front fairing stay and dash. I'm hoping to ride it tomorrow.
Thanks again for the routing diagram.
Old May 13, 2011 | 01:03 PM
SmokinJeff's Avatar
No problem. Good work.
Old Dec 30, 2021 | 03:08 PM
tiredbones's Avatar
Default f2 throttle cable routing, need pics
Hi my f2 throttle cable wont spring back easily either, sharp bend going under frame under tank, think they are routed wrong, should one cable go over frame bar under tank and other underneath currently both cables are going under bar in front of carbs (thats the bar that holds the coils) got new cables coming tomorrow so any help with info or pictures greatly appreciated, thanks
Old Dec 31, 2021 | 08:26 AM
Phil314's Avatar
The correct way to run the cable is so they don't have sharp bends.
I think that means one over and one under the coil bar. But it's been a long time.
So try installing whatever way is the straightest. It will make more sense when you do it.
Also check your hand grips.
I've seen WAY to many installed wrong or use very poor grips that don't fit.
Many times poor throttle snap back is because the grips are rubbing on the throttle housing or bar end.
Old Sep 15, 2024 | 11:51 PM
extamblerr's Avatar
Default CBR600F Clutch Cable Route
Give up on Haynes and get the Honda OEM manual. It has 5 nice diagrams showing the clutch cable (and others) route. Having said that, using that route means I obscure my speedo like everyone else . Either there is a batch of too-long cables out there, or, as suggested above, you need to manufacture a sliding holder to the speed assembly holding arm.
rafa2210
Oct 19, 2012 08:04 AM
bamato
May 24, 2012 09:02 AM
ineedparts
Apr 10, 2011 12:55 PM
quadracer18
Nov 22, 2009 12:33 PM
ajohn505
Mar 16, 2009 10:16 AM
