Brake lever is too sensitive....
Old Apr 17, 2011 | 06:04 PM
xp3085's Avatar
Default Brake lever is too sensitive....
Sometimes my brake lever feels like the pads are sitting right on the rotor. There are other times where it feels like there is a a normal amount of play before the pads actually touch....... anybody deal with this? Hope it makes sense.
Old Apr 17, 2011 | 09:07 PM
backyardmechanic's Avatar
probally the expansion and contraction of the brake fluid, mine does it sometimes
Old Apr 18, 2011 | 03:11 AM
buickid's Avatar
Your seals could be worn out and there could be gunk accumulated in your master cylinder. When I got my bike, the brake lever was very touchy. After I bought a used one off eBay and rebuilt it with the Honda kit (was <$10 if I recall), the lever felt much better. The rebuild kit comes with all the rubber seals, a new spring, and the piston the seals go on. It was surprisingly cheap.
Old Apr 20, 2011 | 11:22 PM
buickid's Avatar
You probably should avoid cross posting the same question in two places, makes it confusing to those trying to help you. I was mistaken about the master cylinder rebuild kit. It is closer to $30, still relatively inexpensive.
xp3085
F2 Tech
Sep 20, 2011 02:01 AM
6doubleohf3
Oct 25, 2009 09:01 AM
aeroworks
Feb 23, 2006 01:21 PM
