94 f2 cuts out in 5&6 gear
Old Jun 19, 2011 | 10:30 AM
jtkardel's Avatar
I don't have that guard and I don't have that issue. Have you done a compression check? Have you checked the carbs out? If the CV boots have a leak it will run like crap at high load as one cylinder won't get enough charge. Could be the plugs too. I doubt it's jetting cause they come pretty decent from the factory. Too rich or too lean on the main could cause this problem, as could needle position. You should be able to see something on the plugs after just a short 30 min ride.
sanlot17
Apr 30, 2014 12:58 PM
devin318
Jul 19, 2010 02:44 PM
Nightangel
May 15, 2009 07:34 PM
CaliKush
May 6, 2009 06:19 PM
surfstyle35
Sep 4, 2008 08:27 AM
