1994 f2 Restore
Old Nov 30, 2013 | 12:39 PM
mkeigwin's Avatar
Default 1994 f2 Restore
I picked this 1994 f2 a couple months ago, was a race bike , needed alot of work , Criags list special, Motor bag not running, so i go over to look at it , do a compression test , ok seem good , a little low, 140 psi across to board, most likely need a valve ajustment, carbs cleaned tires brake gone though, and a upper faring,
Budy has a nice f2 he picked up for 1300 and runs well, not to much work.
so i get it home , clean carbs , starts right up. sounds good not rattles , smokes a little, but seems to run overly good, so i put new tires on it , change all fuild's
Video of it not start up after been sitting for a yr
<iframe width="560" height="315" src="//www.youtube.com/embed/54FUrtnCH_0" frameborder="0" allowfullscreen></iframe>
so then i had it dyno over at marietta motorsports . on go one run on it before the chain ajustment broke and flew off at full power.
was running real rich. has a factory pro jet kit in it . two brothers timimg advance kit and is at 5 deg advance . 140 mains clips 2 snd from bottom on needles
still made 80 hp , so i start going over it , do the valve adjustment , lots of fun, will pull motor next time for that!!check carbs order new main jets , stock + 1 size up and down, clean carbs again, doesn't seem to be running on all cylinders , take a temp reading on headers #4 400deg #3 about same ,#2 290 deg , #1 100 deg , ok so whats going on pull plugs #4-#3 aliitle grey now 100 oct vp race gas , #2 a little black and brown better, #1 black no oil on plugs, all plugs new , so #1 seems to be not working ,
can't find compression adapter to do leak down , pull carbs a little grey ,on intakes so i put plugs back in spray so lube into intake hole and chrank it over , all valves are leaking air on compression stock, ok needs a valve job,
that $300 to send out,
Then i pull plugs again and hold my hand over plug hole to if about how much compression ( remember lost tool) #1 will blow had off head #2 none #3 can feel presser #4 did not do,
so i may have a bad head gasket or rings are shot. how much more do i want to spend. i have a 91 FZR 600 that just got new 1.00 mm over pistons and rings , had the head done right before that, Big $$$$ to have done all this work , i will have to keep that bike until i die .
Old Nov 30, 2013 | 01:05 PM
mkeigwin's Avatar
Video of the running bike
Old Nov 30, 2013 | 06:40 PM
coalminer frank's Avatar
I check the temp on my header pipes near the head and got what I thought was too much of a difference (cant remember exactly what they were). But my basicly stock bike with K and N, jet kit and full header made 86.64 hp, runs great, I think, and I have an 08 CBR 1000rr for the street. The F2 is track only. Also, practice your typing skills, it kind of hard to figure out what you're saying.lol
Old Dec 14, 2013 | 07:54 AM
mkeigwin's Avatar
so i pulled the head , took it to the machine shop , head is not warped, the intakes did leak some. i have been waiting on tools to get here, bought a new valve spring compressor & a Bore gauge.
when at the machine shop ,talking with him about what was going on, he said that it could be low compression , stuck rings, or as simple as a bad coil. i thought for sure a blown head gasket, well i am doing the valve job now , only have to lap valve in and then order new oil seals,
reaper101
Aug 10, 2014 12:46 PM
Douglas_1987
F2 Tech
40
Jul 23, 2013 09:27 PM
sharkbaitjoncbr
Mar 10, 2013 06:07 PM
Armyof1
Dec 28, 2011 04:58 PM
kilgoretrout
CBR1000F For Sale / Found
Dec 2, 2009 10:26 PM
