Drag Racing Raced a guy from a light? Been to a night at the track?? Tell your story here.
drag strip
Old Aug 19, 2006 | 03:48 PM
04cbr's Avatar
Default drag strip
Last night was the first night I have ever run at the track. I only got two runs in because we got there kind of late. The first run I staged, popped the clutch at 5k and pulled the front wheel up about 2 feet. I had a .586 light, 2.275 60', 8.057 1/8, and 12.092 @120.05. The second run I didn't tach it up as much and slipped the clutch and bogged it. .703 light, 2.564 60', 8.366 1/8, and 12.425@119. Are there any techniques to improve 60' i.e. tire pressure, postion on the bike off the line, etc. What are realistic times on a 04 600f4i for a 145 lb. rider?
Thanks Rob
Old Aug 19, 2006 | 05:55 PM
pilam's Avatar
Default RE: drag strip
i had an f2 that i ran under 12 no problem the bike has 86 rwhp the best that i have ran is a 11.6 at around 118mph for my launch im @ about 7-9000 rpm and slip the clutch out little by little till i can feel it start to grab thats b4 the guy next to me stages ill hold the bike back and once that last amber turns on slip the clutch out till it really grabbs hard and then WOT and power shift the frst of the way....my 60 ft times were something like 1.9 with an rt of at best .003-.5
Old Aug 21, 2006 | 02:10 PM
ClutchBurningRacing's Avatar
See the team name? slide that clutch out untill it hits the rev limiter if you have to. pilam is right, pre-stage your clutch at the line. leave on the last yellow, throw the clutch out hard until the you fell the front end start to lift and slightly pull it back in just enough to keep the tire skimming on the ground. slowly let it out all the way. I have watched Ricky Gadson and Vince Woska slide the clutch all the way thru 1st gear and never put the wheel on the ground. if you can master your clutch off the line nobody will touch you! just be carefull!!!! i have seen four flipovers this year! all on 600s.
Old Oct 4, 2006 | 05:45 PM
06rr600211's Avatar
hey wats ? on my 06 rr600 i leave at 12.5 and i slide the clutch out and i pull 166 60 foots and my best is a 10.40 at 130mph. its all in the clutch if u cant 60 foot u ant really goin to do that well unless u got a big hp and tq bike .
Jay_J
Oct 11, 2010 09:19 PM
teenbmxer
Jul 10, 2010 01:45 PM
SeattleSy#1255
Sep 7, 2008 08:59 AM
sean_carman
Dec 1, 2006 10:21 PM
shiphteey
May 12, 2006 11:20 AM
