where to find ignition on power only
Old Oct 10, 2006 | 11:39 PM
linkandcuff's Avatar
Default where to find ignition on power only
i need to run some power to my new grip heaters (which are 100% awesome!!!) but i have it wire so even if i turn the bike off they can still be on....whats the easiest way to get just power when the bike is running or on the on the position....thanks
Old Oct 10, 2006 | 11:46 PM
doncollins's Avatar
Retired Administrator
Default RE: where to find ignition on power only
Wouldn't you rather use a switch to kill the grip heaters when it's warm out?
Or are you just wanting to make sure you don't forget to turn them off?
Just use a test light on your fuse box and pick a fuse that's only hot when the key is on.
Old Oct 11, 2006 | 12:04 AM
only so i dont forget to turn them off....right now they have a high low off switch but i already forgot to turn them off and now i have a dead battery....i'll check out the fues thing....i know i'll be able to go off the highlight one but i dont want to take too much power away from anything....we'll see
Old Oct 11, 2006 | 12:08 AM
doncollins's Avatar
I know what you mean... that's why I suggested running the wire right off the fuse box supply so that you're not adding any stress to your lighting wires. I'm sure the heaters pull a couple of amps and would add a lot for heat to your lighting wires.
dylan-pb
Aug 3, 2023 02:12 PM
kemper
May 7, 2015 07:22 PM
Deltemis
Apr 22, 2012 07:48 PM
mgabs06
May 18, 2009 11:24 AM
snobrdrdan
Apr 30, 2006 02:40 AM
