Weird 954 problem
Old Mar 29, 2008 | 02:36 PM
  #21
ReSpEcT's Avatar
Default RE: Weird 954 problem
e more, where i can actually see things now...Green wire at the FP plug has a good connection to every point where it is suppose to connect. Also that green wire is the one that runs the tailight also. So since my taillight is working and brake light is working. Its safe to say the green wire is not a problem. IF there was an open or a short on the green wire, nothing on that wire would work because it would keep seeing the open or short (so scratch the green wire). HOwever, that still doesnt explain why my headlights do NOT work....Next up, Brown wire on the FP plug will turn into the Brown/Black wire at the fuel cut relay....I'm going test the connection from FP plug to that relay side and see what i get.....Since it clicks, i would say its "probably" good, but im going to check.............start/stop switch is next in line, but it looks good so far....=-)
Old Mar 29, 2008 | 03:39 PM
  #22
Hcstreetriding's Avatar
Missed a huge factor in all of the searching. Test your headlight realy. Bad headlight relay=no power to the front of the bike and also engauges the kill engine relay and that is why it wont start.
Old Mar 29, 2008 | 03:59 PM
  #23
ReSpEcT's Avatar
ORIGINAL: Hcstreetriding
VERY good point and you are correct i did miss that. I will go check that ASAP....On another note...Green wire at the FP plug has 12.40v (voltage meter black on FP plug and red on battery)...And it has that 12.40v even if the key is off or on (does that make sense). I can also disconnect the tip over senor and it still has that 12.40v........I swear im missing something realy simple around here....=-)
Old Mar 29, 2008 | 05:28 PM
  #24
skarocka's Avatar
ITS A 12 VOLT BATTERY SO U WILL HAVE 12 EVERWHERE IS THERE A STEP DOWN, GET YOUR MULTIMETER AND A ROLL OF TAPE AND START CHECKING EVERY WIRE I KNO ITS A LOT OF TIME BUT U SEEM TO HAVE DONE EVERYTHING ELSE CHECK ALL THE BUS CONNECTIONS SEEM TO BE ALOT THERE, ILL KEEP LOOKING OVER THE SCEMATICS FOR YA SEE IF I SEE NE THING
Old Mar 29, 2008 | 05:45 PM
  #25
ReSpEcT's Avatar
Ok tell me whats wrong here......The blue and grey plugs at the upper wiring harness, where it connects to the main harness.....On the MAIN harness side of the blue plug. Theres a green/grey wire that i know IF its cut, it'll trip the tip over sensor....Anyways, on that wire on the MAIN side of the plug, there is ONLY 12.40v when i touch the black of the multimeter to that wire and the red of the multi meter to the battery (does that sound right). And that is with the key off or on.....Did i miss something else....=-)
Old Mar 29, 2008 | 06:20 PM
  #26
skarocka's Avatar
check the solenoid but there is always current just a matter of wether its used or not
Old Mar 29, 2008 | 06:27 PM
  #27
skarocka's Avatar
when u connect them u r completing the circuit
Old Mar 29, 2008 | 07:29 PM
  #28
AAnderson's Avatar
CHECK your kill switch again. I thought I had the same problem back in the day. It sounds stupid, but if everything else works, just flip the kill switch and see if the fuel pump comes back on. It took me like 15 min to figure out I needed to flip the kill switch one day. Sounds stupid- yet might be the simplest solution.
Old Mar 30, 2008 | 07:41 AM
  #29
FastFreddieRR's Avatar
like Hcstreetriding stated, check that headlight relay!! jump it, sounds like it might be a bad ground cause of the cluster is dim, also check the ground connection under the the tank that's bolted to the frame, take it off and clean the conacts, and fire that bad boy up!
Old Mar 30, 2008 | 11:18 AM
  #30
ReSpEcT's Avatar
Sooner or later i will figure it out. As always, its a process of elimination. But you wanna see something that will break your heart?...Heres some pics of my 03 European Edition 954rr toren to pieces, just because the damn thing doesnt turn the fuel pump on, LoL......Sucks when your minty bike is down to this point. That goodness i still have HER f4i, haha.....=-)
