Vacuum Hose's
Old Mar 29, 2016 | 04:40 PM
mutley's Avatar
Default Vacuum Hose's
Hi All,
Honda Fireblade CBR954RR 2003
Just rebuilt the gearbox after suffering from the bike jumping out of second gear.
Having a little problem with a vacuum hose or two
I have one long hose with a 90 angle connector part way up it, I think one end went to the MAP sensor and one end to the fuel tank vent, the long section then vented to ground? See picture
I have then noticed a vacuum hose on the throttle body, it looks like all throttle body's have a short vacuum hose going to a five way connector block, this hose then comes of the connector block, where does it go? See picture
Many thanks for you help
Old Mar 29, 2016 | 05:09 PM
74demon's Avatar
The MAP sensor will not be connected to fuel vapor hoses. It will connect to Manifold vacuum.
Here is the diagram from my California model 929. The 954 should be the same. The only difference is that I have an EVAP canister.
Old Mar 30, 2016 | 04:39 AM
mutley's Avatar
74Demon, Thank you
Can any one help with where the fuel tank vent hose, and where do the 2 ends go to please
Thanks
Old Oct 5, 2016 | 03:44 PM
davebelcher's Avatar
They are just vent hoses mate, 1 end goes to the fuel tank and the other end with the t piece just hang loose. hope this helps
Old Apr 28, 2017 | 05:32 PM
Jimdav232's Avatar
Originally Posted by mutley
Hi All,
74Demon, Thank you
Thanks
Honda 929 map sensor. What pipe connects to too it
Old Apr 29, 2017 | 09:20 PM
74demon's Avatar
What pipe? It connects to the hose from the 5 tee that also goes to the throttle bodies. Look at the diagram....
Old Jun 19, 2022 | 01:28 PM
Shep's Avatar
Hi All,
Attachment 27094
Attachment 27095
I have same problem but there is one on other side too. U ever find where it goes
Malibuskiboats
Nov 19, 2009 09:32 PM
icedime99
Jul 23, 2009 08:44 AM
CBR Chic
Apr 13, 2009 05:30 PM
brnksman30
Sep 26, 2008 12:04 PM
danny_l_2005
Jan 30, 2008 08:29 AM
