TooBroke rebuild 954 thread
#101
#102
My other issue is going to be painting the tank. I can easily manage the body work and primer, but Dont have an adequate air compressor to handle the paint guns. So ill have to use aerosols instead just worried bout the clear hardening in the can and having to buy more.
Any advice or tips are appreciated.
#103
#104
#105
Here you go!
High Volume, Low Pressure Spray Gun Kit
Like I said earlier, I haven't had any issues with it. I've ran primer, regular paint, latex, lacquer and clear through it. It does a good job for the money.
#106
Not sure when it'll be done I mounted the front fairing today but realized I'm missing some more screws.. Ordered them so we will see when they arrive.
#107
Here you go!
Very interesting to say the least, I would have never looked at a product like this if you hadn't mentioned it. From the reviews( including yours) it seems top notch. Thanks hamlin6
I didn't know you were painting it yourself. My experience with aerosol paint jobs especially on the tank is this. If gas gets on the paint it is screwed. The majority of aerosols does not protect from gas. So that is something to think about if you are going to do aerosols.
No updates today feeling under the weather ate some bad food for lunch put me out of commission for the rest of the afternoon.
I hate being mortal sometimes.
#108
Yea, I will admit it looks a little hokey. The reason I bought it was the reviews and the price. I figured worse case, I could paint whatever needs painting on my honeydo list. But I'm really glad I bought it.
#109
Sorry for posting such terrible pictures all the time the garage is packed buddy has his projects 05 gsxr 1000 03 600rr 86 kz1200(?) And then my bike(s) tools and everything else. I started mounting the fairings they seem to fit fairly well but I have to mess with the right side some more. There a decent gap where the front and side meet and it will annoy me to no end till its fixed.
Had issues with the turn signals I purchased. There flush mount with a plastic but on the back but there's really nothing to mount it on the fairing. Only the inner fairings? When I looked at parts fiche it shows a factory grommet but I'm unclear as to how large it is or how much it will pull the signal out.
So instead I mounted ones that came off of one of the extra fairings ended up soldering a factory plug and heat shrinking the wires.
Its starting to come together.
#110
Got some parts in today and should be able to put it back together completely in the upcoming weeks.
Decided that once I'm done with the bodywork on the tank. I'll just drop it off at a local shop and have them spray it.
On other news I am having the worst time trying to get this think to run! After several short and crummy idles she just quit. After reading around and thinking about it I realized my map sensor was disconnected.
I reconnected it and hooked up the lap top but still diesels at best for 4 seconds. I swapped out the map sensor since I had an extra lying around but marginally better. This is very depressing since it ran like a beast b4 I took it apart. I'm going to grab some fresh gas tomorrow drain the tank and see what happens with some fresh 93 octane.
Very discouraged right now.
