Tire PSI Reading
Old Feb 22, 2011 | 02:55 PM
haaris954's Avatar
Default Tire PSI Reading
So I got this new digital gauge to check my tire pressure and my front tire reads 20 PSI and rear 25 psi. It should be 36 and 42. I tried putting more air in but tire seems pretty inflated.
Could the gauge just not be reading it correctly? the gauge works on my car just fine, i called the manufacturer and they said the bike valve might be jammed?? Any ideas on what I should do?
Old Feb 22, 2011 | 03:12 PM
Piranha's Avatar
Put a new valve in the stem.
Old Feb 22, 2011 | 04:02 PM
letsride's Avatar
Just replace the schrader valve with a new one and reinflate.
Old Feb 23, 2011 | 05:00 PM
haaris954's Avatar
Thanks guys - got the new stems and the screwdriver lookin tool to take them out and put in. GOing to try and make time to do it this weekend! Lets see how it goes.
Old Feb 23, 2011 | 07:14 PM
letsride's Avatar
Should take less than a minute per wheel to do.
Old Feb 24, 2011 | 11:47 AM
moosestang's Avatar
I run 34/36 in my tires. When I bought the bike, the front tire was at 20psi. What are you using to add air?
Old Feb 24, 2011 | 03:44 PM
haaris954's Avatar
I used a campbell hausfeld 100 psi max air compressor.
Old Feb 26, 2011 | 04:53 PM
theskater101388's Avatar
jus double check with a.... "mechanical?" one if anything to be safe
Gnarly 928
Jun 24, 2013 01:09 PM
tremblemcp
Apr 10, 2007 03:17 AM
demonchild
Feb 19, 2007 10:08 AM
Hanberg[DK]
Jan 22, 2007 07:34 PM
Winchester
Oct 29, 2006 01:44 AM
