Timing Chain Change
Old Apr 5, 2009 | 06:57 PM
BottleFed954's Avatar
Default Timing Chain Change
So Ive deceided its time for a change of timing...... Or time to replace my timing chain and adjust my valves. Has anybody else done either? Is it easy to do yourself? Any special tools needed? I bought the chain and valve cover gasket and have shims. Any input would be very helpful. Thanks in advance
Old Apr 5, 2009 | 08:56 PM
not_agn's Avatar
A service manual will tell you what you need to know. Do you have a manual cam chain tensioner? Or is it still factory? If your doing the chain, I would recommend changing the tensioner.
Old Apr 13, 2009 | 07:55 PM
I have the manual. Planned on using the factory tensioner. How about valve shims? Easy to measure and adjust??? Does the motor need to be taken out or can this be done with the motor still in the frame???
Old Apr 13, 2009 | 08:00 PM
not_agn's Avatar
It can be done in the bike. Kind of tight if you have to reshim the cams, but possible. Need a mirror to read the timing marks on the cam gears.
Old Apr 13, 2009 | 08:56 PM
nikos's Avatar
I just did the valve adjustment, and I did it in the bike. Only one of mine needed adjustment. I took a bunch of pics, and sometime this week, I was planning on putting together a tutorial. It's not too hard, just take your time, and if it looks like it's going to be in the way, take it off or move it.
My $.02
Old Apr 17, 2009 | 10:51 PM
j4eric's Avatar
Default valve adjustment
do you have an f4i?if so here is a link
http://www.bayarearidersforum.com/fo...t=85499&page=2
OZZY_F4
Dec 17, 2024 07:04 AM
tecsterF4
May 8, 2011 08:34 PM
XxKyle082xX
Aug 31, 2010 01:07 PM
408_954
Jul 26, 2006 02:39 AM
morpheous283
Apr 12, 2006 08:07 AM
