Temperature gauge on '03 954rr
Old Mar 11, 2007 | 12:52 PM
Iguana954's Avatar
Default Temperature gauge on '03 954rr
Hey, I recently sold my '97 F3 and stepped up to an '03 954rr. I just had a couple questions. First is does anybody know if there is an owner's manual available for download on the net somewhere? I downloaded the service manual but I would prefer the owners manual. My other two questions are is there any way to change the temp gauge from celsius to farenheit? And what should the bikes normal operating temperature be.
Thanks for any input.
Old Mar 11, 2007 | 12:55 PM
Iguana954's Avatar
Default RE: Temperature gauge on '03 954rr
I had one other question as well. When the bike is at normal idle speed, and I tap it down into first gear, it clunks pretty hard, harder then my 600 did anyway. I just want to make sure that this is nothing out of the ordinary.
Thanks
Old Mar 11, 2007 | 01:00 PM
bobjoezx's Avatar
change the temp reading on the gauge you hold down one of the buttons, also, the chuck, waht do you have your idle speed at ? should be about 900 - 1200.. i put mine right at 1000... that will have some effect alsoi would have to say that is pretty common without actually hearing the cluck
Old Mar 11, 2007 | 01:31 PM
Iguana954's Avatar
I got the temp gauge thing, two more questions, how do you adjust the idle on the 954 and number 2, how do you check your oil? I pulled the oil cap off and theres no dip stick. Im guessing soon would be a good time to buy the manual.
Thanks
Old Mar 11, 2007 | 02:53 PM
bobjoezx's Avatar
idle is on the left side.. black screw type .. turn it to briing idle down or up.. also oil.. there is a window on the side of the crankcase and a few notchs to tell u wehre to be.. a tad above the middle of the window is the best
hhaarrvvyy
May 14, 2012 09:18 PM
scottiekarate17
May 8, 2012 05:59 PM
iBang
Jul 15, 2010 12:15 PM
Ayres_08
Jul 6, 2008 11:39 AM
