suspension set up
Old 11-07-2005, 01:29 AM
rolling's Avatar
Default suspension set up
Would some of you hook me up with some ins and outs of suspension set up from stock?
mostly the rear
spring set point stock is 4
compression stock is 2 revs from full hard
rebound 2 back from full hard.
Thanks guys
Old 11-07-2005, 03:58 AM
Default RE: suspension set up
Riding style has a little to do with the way you want to set it up. I ride fast CURVY highways and try to stay away from the city cruising. Weight is also an issue. Factory suspension on the front forks is rated for riders around 175lbs. so Ive got mine cranked up all the way on preload with a half turn back from full hard on rebound and compression. It makes for a stiff but sticky ride. As for the rear my spring is on the 7 notch with one full turn back on compression and rebound. Oh, I way 190lbs. so be your own judge. This is what feels good for me and my style.
Old 11-07-2005, 12:55 PM
I found this site and thought you would be interested. Very detailed.
http://www.sportrider.com/tech/146_0006_susp/
Hope this helps you.
doc6335
07-19-2012 09:05 PM
thatdarkknight
09-19-2006 11:06 PM
PERT1905
09-19-2006 12:14 AM
exup547
09-14-2006 08:10 PM
exup547
09-14-2006 04:40 PM
Quick Reply: suspension set up
