Suspension
Old Aug 2, 2007 | 05:44 PM
TCIRACING's Avatar
Default RE: Suspension
LOL!
NAH I DONT SELL THEM, NOR DO I WORK FOR B'STONES, TRIED 3 SETS BRAND OF TIRES ALREADY (DUNLOP, MICHELIN AND B'STONES) THE M-PILOTSARE SMOOTH, TURNS VERYEASY AND STICKY, BUT THE DOWNSIDE IS THEY ONLY LAST ME 2,300 MILES, THE D-QUALIFIERS LASTS LONGERBUT LIKES TO SLIDEIN COLD OR WET CONDITIONS, THE B-BATTLAX 015'S ARE THE LATEST ONES I PUT ON MY 54 AND PERSONALLY I THINK THEY HANDLE WAY BETTER THAN THE D'S AND WEARS BETTER THAN THE M'S
ANY PIRELLI'S OUT THERE PLEASE GIVE SOME FEEDBACK, THANKS!
Old Aug 2, 2007 | 06:18 PM
outsider8's Avatar
ORIGINAL: vpsophmore
I guess I'll take it in to get resprung cuz I've never done this either I always newit would help but I've never tried anything
should you get the forks resprung-do at the same time that you are having the fork
oil replaced
also-with the correct spring tension for you weight-expect a completely different
bike-and i mean this in a good way!!-also do the same for the r/shock
Old Aug 3, 2007 | 12:11 AM
motoxxx43's Avatar
You guys that have not messed with your suspension have no idea what you are missing! That is one of the first things I have got to do to my bikes! I love talking to people who ride an have never touched their compresion or rebound settings. Some people tell me " It is just fine the way it is, I dont need it adjusted"... How ignorant! I have adjusted bikes that were brand new for my buddies. You would crap your pants if you saw how uneven some of them came strait from the shop! My buddies new gsx had the compresion cranked up on the left fork and down on the right! If you would even check them and make sure they are even you might just help yourself out.
Old Aug 11, 2007 | 12:39 PM
beckpack's Avatar
i loved the pilots when i first got the bike, then i tried to get them, they were backordered for 3 months. i went with the metz sport tech...love them, but next set im going back to pilots.
Old Jan 14, 2009 | 08:11 PM
poker's Avatar
Registered Users
I typically dial in my comp and rebound before going out on the track every time. The settings change constantly, so I have to read the tire (check out catalyst reaction suspension) and give the bike some pushes and pulls and twiddle ***** before going out every time. Write the stuff down too. You won't remember what your settings are. And double check (turn the ***** all the way in and back out the specified number of clicks, don't just back it out a click on both sides) if you've put more than a few hours in.
I'd post my settings but they constantly change. For me, I found my bike to be grossly undersprung from the factory, and with the stock springs I crank in all the preload I can. Another little helper is the zip tie (loose enough to slide) around the fork tube (lower) to help you know how much travel you are using up (try to use up most of your travel). Start off with the sportrider recommended settings, but remember to adjust for temperature and conditions (typicall dial in more compression and rebound). If I remember right my forks were last at 3 turns out on compression and 2.5 turns out on rebound (I know - should've been way stiff/slow), I can't remember my shock, but maybe those were bad settings as the crash truck had to bring my bike in from T3 infineon. PS - Warm day
doc6335
Jul 19, 2012 09:05 PM
thatdarkknight
Sep 19, 2006 11:06 PM
PERT1905
Sep 19, 2006 12:14 AM
exup547
Sep 14, 2006 08:10 PM
exup547
Sep 14, 2006 04:40 PM
